2019-03-04 08:28 AM
2019-03-04 12:23 PM
2019-03-04 01:59 PM
2019-03-04 02:34 PM
LaszloNagy wrote:Thank you for the tip, I just tried it and it works but it seems this is not possible for a T junction type.
If you select connected Walls before moving the Wall, then ARCHICAD will treat consecutive Wall Reference Lines as a Polyline and you can edit it as a Polyline. If you then offset the Wall using Pet Palette commands, the connected Wall will also adjust in length.
2019-03-05 05:19 AM
AC22-23 AUS 7000 | Help Those Help You - Add a Signature |
Win10 | R5 2600 | 16GB | GTX1660 |
2019-03-05 08:08 AM
2019-03-05 09:40 AM
2019-03-05 10:05 AM
