Wishes
Revisions Field in Autotext
I know something like this has been discussed before, but could we please, please have a field in Autotext called 'Revision' which gets added to the file name in publisher between the Layout number and the Layout name, so that the first revision of:
P_300 Plan.PDF
will be saved as:
P_300_A Plan.PDF
to eliminate the risk of the revised layout overwriting the previous issue.
Not difficult, surely. But so important for our practice, and, judging from the previous feedback, for many many others.
(Of course, it would be really nice if it could be linked to a revisions notes panel on the layout, but I guess that would be just too much to ask)
27 REPLIES 27
Wokka
Yep, we definitley need some autotext that is available for each individual layout.
Warwick Lloyd-Martin
3 D E N V I R O N M E N T
http://www.3de.com.au
Windows 11 Pro 64bit
ArchiCad 4.55>27 AUS
Lumion 12.5/2023
D5 Render
Are you guys aware that you can create as many custom Autotext items as you want?
Achille Pavlidis
No, please share your knowledge.
Mac OSX 13.6.6 | AC 27 INT 5003 FULL
this wish has been around for a few revisions of ArchiCAD and I'm sure would only require a small time investment by GS to give a huge benefit to users.
Laslo you may not understand but it is per layout...not global
Yes, but if I create a field called 'revision', I don't see a way of getting this incorporated in the layout number, and hence into the published file name.
Wokka
I think we need something like this...
Lumion 12.5/2023
D5 Render
wokka i like your animated gif
going from green to red are you getting angry...
....or is it red to green????!!
What I meant was that in the Project Info Dialog you can create new custom entries and use these as AutoText in Text Blocks on Layouts.
One of them could be called Revision Number.
Of course one would have to change the value of it at each revision so it is not an automatic thing.
So let us say there is a new revision, one saves a new PLN file and then changes this entry to the new value in that file.
Achille Pavlidis
Sorry, that is not usefull.
In a project there can be layouts with revision 0, others with revision 1, revision 2 etc...
The revision field must be layout-related, not project-related.
Learn and get certified!
