Wishes
SEO renovation status/filter
SEOs would a lot more usefull is you could activate them on different renovation status and filters. For example an SEO that is active only in Existing Status and another only in New. Just like walls objects etc that we can set their Renovation Status and filter.
4 REPLIES 4
Emre Senoglu
Surprised to see there isn't a bigger demand for this - it would greatly enhance the renovation tools.
AC26 ARM // MBP M2 Max // Twinmotion | Corona | Rhino
www.senoglu.dk
PB
I agree: Definitely "essential"... as part of a far more extensive upgrade of the renovation filter.
AC27 Apple Silicon. Twinmotion.
16" M1 Max MacBook Pro 32GB, Apple Studio Display, MacOS14
Sculptdesign
I'd add my vote to this, the SEO should only be active is the operating elements is visible in that renovation status. Typical example - new slab for an extension, SEO the proposed slab from the existing ground (mesh) then the 'hole' is visible on the existing when it shouldn't be.
ArchiCAD 26 Solo - Mac
Yes, the inability to sequence operations is a real obstacle to a smooth workflow from concept design to building management. A new approach is needed.
