I would like Drawing tool favorites to save the actual extents of the frame when the frame is set to Manually Resized.
Maybe this would require a third frame condition, 'Fixed frame size.' OK by me.
With a fixed frame size, you could have favorites for each sheet and grid cell size, so drawings would come in properly cropped. Then just snap them to the sheet and done.
I understand why they didn't do it. Except for objects, extents aren't considered attributes. But I think that drawings are a special case.
Regards, Geoff Briggs DeForest Architects Seattle, USA AC26 INT, M1 Mac, OS 13.2.1 Yes, you read that correctly, we are in the US but use the INT version, because the libraries are better.
