Wishes
Post your wishes about Graphisoft products: Archicad, BIMx, BIMcloud, and DDScad.
Save Object from bits in PLAN
vfrontiers
Please, please, please allow us to save bits from the plan as an object WITHOUT THE FREAKING GROUPING....
I do a bit of HYBRID object making where I want to manipulate the code after saving objects...
This is virtually IMPOSSIBLE with the code gets generated with all that GROUPING crap!...
Maybe its a TOGGLE during the SAVE AS OBJECT that says... INCLUDE GROUPING... (checkbox)...
Thought for today, anyway...
(also, please allow us to assign a SUBTYPE while saving... Bugger having to save a light as an object, then go change it back to a light)...
Duane
Visual Frontiers
AC25 :|: AC26 :|: AC27
:|: Enscape3.4:|:TwinMotion
1 REPLY 1
Podolsky
Ace
ArchiCAD uses GROUP command while saving GDL because of solid element operations.
If you would have possibility to switch off this GDL "style" - then all SEO would be unavailable.
Unfortunately automatically generated scripts very often have a lot of "crap", that human would never write.
