2004-10-12 09:57 PM
2004-10-12 10:13 PM
2004-10-12 10:17 PM
Mike wrote:Move Section? Do you mean move the end points?
3. The ability to have the same sect/elev have independent marker locations on different stories. A classic example would be a second or third story that is much smaller than the stories below. We need to be able to move the marker location and still have it linked to the sect/elev cut (ie right click on the marker to open the section).
2004-10-13 12:03 AM
Move Section? Do you mean move the end points?My point is to move the graphic that represents the section (this will show up on final printed plans) in a manner that is independent of the defined cut line. Moving the "end points" is perhaps saying the same thing. However, with elevation markers in the floor plan view, I would like to be able to move the entire marker such that it can be positioned anywhere without moving the actual elevation "cut line".
Because Moving the section from floor to floor has no meaning since a section is done verticaly.
I guess you mean move section end points but staying in the ref line
2004-10-13 12:30 AM
2004-10-13 03:45 AM
2004-10-13 04:45 AM
Weston wrote:Unfortunately the Section Symbol subtype does not support any hotspots, movable or not. I will keep reminding GS of this as opportunities arise. It would allow GDL guys to make some really cool section markers.
mike-
great suggestions that gs should include! Matthew Lohden suggested adding a parameter to the marker gdl that would allow you to move the head. I haven't tried it since he suggested that there was a problem in that the hotspot was not graphicly movable and would have to be entered manually.
Matthew - any further developments along those lines you can share?
voting for essential...
wes
2004-10-13 08:16 AM
2004-10-17 05:47 AM
2004-10-17 10:16 AM
Mike wrote:this is actually acheived with archiCAD 9 (at least the markers in the INT library . . . ?). it
