2017-04-12 06:19 PM
2017-04-12 07:24 PM
2017-04-12 07:27 PM
2017-04-12 09:53 PM
2017-04-12 09:56 PM
Bruce wrote:Or a pop-up - "Items on multiple stories selected - which storey would you like to go to?"
Did a search, couldn't readily find a previous poll.
If multiple items selected, ArchiCAD picks the lowest floor (this is done when "Merge Uniform Items' is checked.
2017-04-12 10:50 PM
Bruce wrote:Not so easy to find sometime - I know.
Bruce wrote:I was referring to you saying you wanted to select objects in elevation/3D which is very easy to do across multiple stories when you select multiple objects.
Multiple items can be selected in schedules - this is done when "Merge Uniform Items" is checked. In this case, ArchiCAD will go to the lowest floor of the selected elements.
2017-04-12 11:03 PM
Barry wrote:Barry,
And what happens if you select multiple objects on different storeys?
Which plan view will it open and select?.
The schedule does it but only select what is in the current storey.
A single object is no problem but I am guessing multiple objects on different storeys is why this option does not exist.
There may be other reasons as well.
2017-04-12 11:06 PM
