tlodge wrote:
Thanks Barry I wasn't aware that that function was present.
However, the down side is that if you then change a thickness of one of the skins you will need to update the custom 'reference line off set' of that composite which would be quite tedious and require recalculating where it should be.
Old thread, but missed it when posted...so maybe this will help someone...
There is no way to make the reference line dynamically stay assigned to a particular skin with Composites. But, the recalculation of the offset is eased by the Modify Wall group of commands: Design > Modify Wall > Reference Line ...
Use Find & Select to select all of the modified composite walls (I usually do this in 3D to visually confirm that I have gotten all walls on all stories) and then invoke the command. See attached screenshot of the dialog. As long as your desired offset is to one face of the core skins, this will save lots of time and avoid math errors adding the outside skin thinknesses.
If you want to be SURE that the reference line is always at the desired skin, then use a complex profiled wall instead of a composite. Just capture the composite the first time to make the profile. [Design > Complex Profiles > Capture Profile of Selection command] Locate the base of the reference line by positioning the entire profile assembly over the origin in the profile editor. Now, any future editing will adjust all placed walls relative to that origin - so if you change the skins, just move the assembly so that the new reference line position is at the origin.
Karl
PS Back to the original wish: I vote essential. It would be easiest to be able to specify the reference line int he Composite dialog itself ... and perhaps have a 'lock' icon to indicate that it cannot be later moved via the offset (just like a CP wall).
One of the forum moderators
AC 27 USA and earlier • macOS Ventura 13.6.6, MacBook Pro M2 Max 12CPU/30GPU cores, 32GB
