Wishes forum
Show 2d on another story
Ability to show anything on another story, not just model parts.
11 REPLIES 11
Daniel Kovacs
Do you mean the Trace & Reference function? Is something not going through for you with that? Can you give me some examples?
Thanks,
Daniel Alexander Kovacs
GRAPHISOFT
I think frankyvero is referring to 2D elements and possibly walls and beams having the same storey settings as roofs and slabs.
Versions 6.5 to 25
Dell Precision 3510 - i7 6820HQ @ 2.70GHz, 16GB RAM, AMD FirePro W5130M, Windows 10
Daniel Kovacs
If so, have you tried turning them on in the Trace & Reference Palette?
Regards,
GRAPHISOFT
Thanks for your response dkovacs, Barry is correct with his elaboration. The trace function would defiantly help the problem if it was document-able (printable).
Stress Co_
It is:
(But if I remember correctly, you'll have no control over pen weight/color)
Marc Corney, Architect
Red Canoe Architecture, P. A.
Mac OS 10.14.6 (Mojave)
Processor: 3.6 GHz 8-Core Intel Core i9
Memory: 48 GB 2667 MHz DDR4
Graphics: Radeon Pro 580X 8GB
ArchiCAD 24 (3022 USA Full)
Can print but can't document. You can't plot it and incorporate into the layouts, unless I am wrong.
Daniel Kovacs
I think if you want to place drawings of different floors under each other on a layout, you don't actually need the Trace feature, you can just place a single drawing of each floor under each other on a layout. Make sure to turn the background of the drawing to transparent, and if you want the "reference" to look different, just override its pen set from the drawing settings, or save the view with an override.
Does this help in what you would want to achieve?
Regards,
GRAPHISOFT
That is what I do, but it is very annoying.
I voted average, someone else thought is was more important than me.
Lingwisyer
Above average, but not essential?
I have one project where I have needed to place a series of hotspots on every floor in order to get them to line up consistently on layouts...
Ling.
AC18-23 AUS 7000
Self-taught, bend it till it breaks.
Win10 | E5620 x 2 | 24GB | K2200
Darren_Kilker
I might be missing something, but would changing the cut plane settings allow you to do what you are describing? The cut plane can be set for a view in AC21 (and maybe earlier versions). The "Floor Plan Cut Plane Settings..." are accessed in the "2D/3D Documents" section of the View Settings dialog.
