Wishes
Post your wishes about Graphisoft products: Archicad, BIMx, BIMcloud, and DDScad.
Show section marker depth when selected
I wish section markers showed their depth and distant depth when selected, maybe as a ghost with their handles. Pretty much like text shows the handles when selected, even if it is not set to display the box.
Having 'working' View Sets with textboxes, section depths, hairlines etc. is the way to handle this today, but the depth and distant depths of all the sections and elevations end up creating an unintelligible mess of crisscrossing dashed lines all over the floor plan --so that even in a 'working' View Set you end up getting rid of those sections depths. Except when you want to check or change one, which is when before selecting it you need to go to Display Options. A default 'show depth and handles when selected' would avoid one rather redundant step there (and another one on the way back, once you've checked/modified).
Excellent wish!
Don't forget to vote in your own poll, Ignacio... 😉
One of the forum moderators
__archiben
an important usability issue. i'm sure there are many similar situations whereby a little extra consideration in the feature development would benefit the end user tremendously.
~/archiben
b e n f r o s t
David Collins
I also like this one and the thought behind it: eliminate as many clicks and menus as possible in the interface. The ArchiCAD 9 update did a lot of this kind of thing and it made a huge difference in everyday productivity.
David Collins
Win10 64bit Intel i7 6700 3.40 Ghz, 32 Gb RAM, GeForce RTX 3070
AC 27.0 (4001 INT FULL)
