2011-04-22 02:00 PM
2011-04-25 07:22 PM
2011-04-26 09:47 PM
2011-04-27 06:21 PM
2011-04-27 06:33 PM
dhaval7shah wrote:Yep, I frequently use the marquee to help save 3d documents and views
i guess, you have not used the Viewmaps to save '3D views with marquee'.
Yes, the Viewmaps remember 3D projection, filter settings, cutaway, Marquee area, rendering settings, 3D window settings etc.
2011-04-27 06:46 PM
James wrote:Yes, that's really a very useful idea to make marquee editable (like polygons) and also parametric for the elemental filtering. I would add that it should also work as editable 3D section box (like in Revit).
A marquee that could be selected, stretched, offset, holes cut into it.
What I meant by filtering, is a marquee is good for stretching so filtering would therefore only affect the elements as per the filter. ie marquee over the corner of the building, but only want to stretch the walls and slab, not the roof. Something like that anyway. The ultimate editing assistant and selection device
2011-04-27 07:00 PM
2011-04-27 07:25 PM
2011-04-29 09:50 AM
