Wishes
Simplified -OneClick-View Settings
NandoMogollon
Hi all
I know everyone is busy so I'll keep it short:
Combine all current view setting options in to one "View Style" property
With it, you just have to select one "View Style Combination" for your views.
It will make Cloned Views somewhat redundant.
See attached pic.
It doesn't seem to take a year of development... or does it?
well, what do I know.
Nando Mogollon
Director @ BuilDigital
nando@buildigital.com.au
Using, Archicad Latest AU and INT. Revit Latest (have to keep comparing notes)
More and more... IFC.js, IFCOpenShell
All things Solibri and BIMCollab
DGSketcher
Legend
Nando, you really should vote as well!
I quite like this, it would certainly help with consistency in presentation updates. It can be a real pain updating views when a setting gets missed. I know we can highlight a set of views to update them but the results aren't always consistent if something doesn't stick or is mis-selected.
Interesting, and I will also add this to the quick option palette and the quick option bar, to quickly change the view style while we work
NandoMogollon
I guess the Tab interface should be sensitive to it:
- if it's a Viewpoint, all single settings will be available at the bottom
- if it's a View, all you get is the View Style at the bottom.
Nando Mogollon
