Last year I was forced to do a number of projects in Revit and discovered there ARE some things Revit does better than AC, so I would like to put them on the wishlist for the next AC release:
1) Terrain / Site mesh
I find the site mesh to be the most time consuming aspect of building up a model in Archicad, and the slight refinement that came with r14 did not live up to my expectations either.
In Revit it is much easier to create a site mesh with well-formed topography from the surveyor's DWG file. When created, the terrain can instantly show contour lines at pre-determined intervals in plan and in 3D. These contours are automatically self-adjusting if you subsequently change spot levels. You can also define site regions for areas of different colour or material on the topography such as roads and other paved areas. These are still part of the one site mesh. Very fast and simple compared to the various methods we use to achieve the same result in AC.
2) Slabs
Another thing I would like to see in AC is the ability to model a slab in the Z-dimension by inserting node points where required and setting the offset height of them. In AC we make ramps and other paved areas with falls out of roofs, but you still end up with all these individual planes and no way to hide the triangulation lines. In Revit slabs can have node points of varying level, for ramps, ext. paving, etc., not just for the perimeter, but internal node points can be added for this purpose as well. Triangulation lines that this gives rise to can be individually changed to 'invisible lines' where the surface is meant to be smooth, and the final slab is still a homogenous unit.
Could you please pass these wishlist items on to the development team in Hungary, as we all want to see AC outshine the competition on every score!
cheers
Daniel
Daniel Lindahl Architecture
AC20 AUS+BIMx | Dell Inspiron 17 SE IntelCore i7 64bit 3630QM 2.40GHz 8GB ram | Windows 10 Pro
