Wishes
Post your wishes about Graphisoft products: Archicad, BIMx, BIMcloud, and DDScad.
Sketch renderings of floorplans
I hope I'm posting in the right place, please move this post if I'm in the worng category.
I would like the ability to do sketch renderings of floorplans and not just 3D views. I don't believe there is currently a way to do this. Is this a reasonable request?
5 REPLIES 5
Well, you know, the one thing you can say about ArchiCAD is that if there isn't a direct way of doing something, there's almost always an indirect way. 😉
The attached shows a quick (no time taken to adjust params) sketch engine image for a floor plan. Vintage 52 defaults.
Someone else gave this tip on the old escribe ac-talk so long ago I can't recall who it was to acknowledge them:
-Display the plan as you want to have it sketched.
-Save as DWG.
-From File > GDL open the DWG as a GDL object.
-Place the object, select it, and view it in 3D. You'll see your plan as 3D linework.
-Finally, adjust your camera to a top view and generate your sketch render.
Voila.
Also, see Cigraph's ArchiSketchy add-on:
http://www.archisketchy.com/
One of the forum moderators
Stress Co_
...or buy Archisketchy.
http://www.archisketchy.com/Info.htm
EDIT:
Opps, just read the rest of Karls post. Someone delete me please.
Marc Corney, Architect
Red Canoe Architecture, P. A.
Mac OS 10.15.7 (Catalina) //// Mac OS 14.2.1 (Sonoma)
Paul King
... or embrace and acknowledge the medium you have selected artistically, and do not attempt to use it to fake another medium...?
PAUL KING | https://www.prime.net.nz
ArchiCAD 8-27 | Twinmotion 2023
Windoze 11 PC | Intel Core i9 10900K | Nvidia Gforce RTX 3080 | 32 Gb DDR3 | 2x4K monitor extended desktop
__archiben
ha! well said!
~/archiben
b e n f r o s t
TDabney
I have used cutting planes and shown only the appropriate story in 3D and done sketch renderings of the floor plans that way - works well but not text or 2D info.
Tom
TND Architects P.L.L.C.
macOS 12.7
2021 16" MacBook Pro
Apple M1 Max
ArchiCAD 26/27
