2015-04-15 06:04 PM
2015-04-15 06:39 PM
2016-01-12 12:11 AM
laszlonagy wrote:Skylight tool needs ability to span across joints in roofs, eg across ridges or change in slope - currently no elegant way to do this without clunky SEO workarounds to cut holes etc - which then tends to confuse accessory roofing addons (eg CADimage coverings) that need to reconcile holes cut by skylight & hole cut by SEO
There is already a Skylight Tool in ArchiCAD. It can place Skylights into Roofs and Shells. You can also script you own Skylight objects.
