- Select multiple parameters to apply bold, off/on, etc
- Allow the variable name to be changeable by the script
- User created functions.
- Using the first instance of the str command, if the length value is greater than the fraction value, the script collapses
- Preview button in interface window, not just when opened in library part dialogue
- New command to allow a list of defined parameters available in the info box so major parameters can be changed without having to open them up. This could prove disastrous if developers misuse this command, so even if there was just one, that would still be very valuable.
- Infields placed over Images display incorrectly when edited. Use to show correctly in 9?
- Live editing of paramaters on floor plan. Ideally it would be good to display small arrows at a desired location that users could select to bringup a pull-down menu or edit box. This would need to be hidden when printed. This would be extremely good for text, on/off buttons, etc.
