2022-04-25 07:18 PM
It would be nice if there was a special widgit that could be used in property a expression, where you could query a custom wall property for a pen number, and then when you schedule the result of the property expression it would display a color swatch in the schedule based on the color of the pen - this would be great for creating a legend of color coded wall partition types where the plan view partition type coverfill has been overridden by a graphic override so to help understand how the partition types are laid out. Having said that - it would also be nice if when building graphic-overrides that there was a toggle where you select the pen numbers, so that you had an option to point to a custom property for the pen number instead of only being able to select a pen number. This would make graphic overrides more BIM. It is not really BIM if I have to enter the same information in 3 or 4 different places. This is a relational database.... this is a relational database .... this is a relational database....please make is so!
Thanks
