When I build stairs, the part that checks the stairs by stopping you if its "out of range" doesn't let me build a legitimate stair. On a circular stair, the treads need to be 10" min along a circular path, 12" in from the inside of the circle. The risers can be no more than 7.75". The narrowest end of the tread has to be at least 6" deep. But when I input the numbers correctly, it says "out of range"
and stops me from building it. Can this feature be overridden somehow? It would be a better stair builder if it were left to the Architect to make sure it meets code as they are often revised. Thanks for any help.
Gayle Berkey, Architect
Littleton, CO
AC-17 USA, ACPI x64 PC, Win8.1 Pro, i7-2600, 3.4Ghz, 16Gb ram
