2019-08-02 02:02 PM
2019-08-05 03:27 PM
2019-08-06 07:52 AM
LaszloNagy wrote:.
Rex,
I assume you are aware of the Override Object's Linetype/Pens checkboxes in the Floor Plan Display page and Reflected Ceiling Plan display page of the Stair Settings Dialog, and also the Floor Plan Symbol Overrides panel in the Railing page of the Railing Settings Dialog.
Is this (or something similar) what you want or something different?
2019-08-06 12:10 PM
Rex wrote:
The stair setting for the override of the plan symbol doesn't seem to change the arrow fills on the up/down arrow, but that's probably a bug.
2019-08-06 01:46 PM
LaszloNagy wrote:.
You would have to check the "Override Object's Attributes" checkbox and then the Arrow Fill will also be overridden.
2019-08-06 01:51 PM
2019-08-08 02:11 PM
2019-08-08 03:27 PM
LaszloNagy wrote:.
Hi Rex,
I cannot reproduce this case where the whole background fill of your whole Stair becomes red.
Could you save a PLA file which contains only this single Stair element, put it on Dropbox or similar, so I can take a look at the settings?
2019-08-08 05:48 PM
2019-08-08 11:46 PM
DGSketcher wrote:.
I used to get completely frustrated chasing down pen settings in all the GS elements, now I just apply Graphic Overrides which seems to work well for most things if you manage them correctly. It may be an easy solution if you can apply them as required to the various stair parts.
I am actually hoping that at some point GS will drop all the scripted pen settings in favour of GOs or as you have suggested simplify objects with global settings.
