Wishes
Post your wishes about Graphisoft products: Archicad, BIMx, BIMcloud, and DDScad.
Stair finish visibility in partial structure
Darwuhr
Hi, What do you think about not showing the stairs finish elements in both 2D (plan, section, elevation) and 3D when "Without finishes" / "Core only" / "Core of load bearing elements only" is selected?
Podolsky
Ace
To solve this problem I modified library element, that represents stair tread. Looks like stair elements require some polishing.
Podolsky
Ace
I hid them in 3d by modifying the GDL script for the riser and tread, but how to hide them in 2d and show only the structure of the stair?
