2004-04-20 05:47 PM
2004-04-20 06:06 PM
2004-04-20 06:25 PM
Link,That's a good idea - just something at the top of the info box would do.
While we're at how about story info in Plan view too?
Since elements can be visible on multiple stories it is often unclear what story something is on unless the setting is changed to "Own Story Only" and the element remains or vanishes.
I think a simple indicator in the Info palette would do. If we want to get fancy, maybe we could have a tab in the Edit Selection Set dialog that could show how many elements of each type are on what story and let us move them around (or is that too scary?).I dunno - whenever I submit a wish, I try to keep ArchiCAD's ease of use in mind. This could be a little boggling for new users.
2004-04-20 06:49 PM
Link wrote:I don't think this is so much an ease of use issue as an implementation and workability problem. Most new users (and surprisingly many veterans) don't even know about the Edit Selection Set dialog. Besides features that are slightly buried (like this one, Attribute Manager, etc.) tend to be more "power user" oriented anyway.
2004-04-20 07:14 PM
...Most new users (and surprisingly many veterans) don't even know about the Edit Selection Set dialog. Besides features that are slightly buried (like this one, Attribute Manager, etc.) tend to be more "power user" oriented anyway...
...There are enough dark and scary corners deep in the recesses of ArchiCAD to frighten the newbies off rummaging around...My point exactly. Maybe this is a direction that GS should consider going. Making it less daunting for new users to pick up (by staging the learning curve), while increasing the functionality for power users. Incorporate it into a streamlined Add On Manager.
2004-04-20 11:14 PM
Link wrote:try a fully customisable context menu:
And while I'm at it, I'd like to wish again for layer control in the context menu too - just like in the Floor Plan window.
My point exactly. Maybe this is a direction that GS should consider going. Making it less daunting for new users to pick up (by staging the learning curve), while increasing the functionality for power users. Incorporate it into a streamlined Add On Manager.aarrrghh! no! two things on this:
This could be reflected in the pricing structure too.
