Hi All,
Thank you for sharing the issue and I am sorry about the experience!
As Karl pointed out, this is a limitation of ARCHICAD. There are some technical challenges to overcome if the texture for columns is redesigned. As a result, this may introduce some instability to the software when calculating the orientation to apply the texture on the column's surface.
This is a recorded wish in our system already. I truly hope that we can find a way to properly implement this in the future, as I can see its importance in modeling!
Once again, thank you for sharing the issue, and I am truly sorry for the inconvenience that this is causing to your projects!
I wish you all a great day, and stay safe!
Best regards,
Minh
Minh Nguyen
Technical Support Engineer
GRAPHISOFT
