Wishes
To be automatically dimensioned for detail in Schedule.
I wish the Schedule to be automatically dimensioned for detail.
(Refer to the figure below.)
It is recommended to add a new command as an anchor for automatic dimensions. (for example, put then HOTSPOT{2} in door joint (red circle))
new command: (wish)
HOTSPOT{2} x, y, z [ScheduleDimension]
5 REPLIES 5
I assume you are already familiar with the 'Automatic Dimension' option there know? (see image).
This can dimension certain points depending how you set it up.
I am assuming you want to dimension hotspots of your choosing?
It is an interesting idea but I don't think would work with the current choices.
It would need a new one to dimension custom hotspots.
Dear Barry,
Thank you for your reply.
Because the pane size is not the same,
Often need a lot of manpower to mark,
I hope to reduce the processing time, and human error.
So i hope that GS can think of ways to implement.
DGSketcher
Legend
I have been hoping for this with objects other than doors & windows. I have a panel in GDL which requires each one to be dimensioned with overall & opening sizes, I could save hours if this was automated.
The dimensioning process could be based on only referencing dynamic hotspots for dimensions which are parallel to the schedule projection plane?
Just a thought.
After changing the size of the sash, it need to be re-mark.
It was so tired!
The following figure is my description
Another wish:
The label can be associated with geometric methods.
