2022-06-10 07:24 PM
We are working with team in Europe and United States, we both have different systems, plus some furniture/ have inches in specs, some in cm... its just time consuming to go to menu & select dimensions (3-4clicks) and during the day this all quite consume time. is there option to have toggle for this? One click and done? can't be so hard?
2022-06-10 08:28 PM
Pls can you explain more this operation for converting from inches to metric and vice versa.
2022-06-12 07:07 AM
Are you talking about the display of dimensions in the Tracker Working Units or the Dimension Tool?
If it's the Tracker, you would have to the Working Units through Options>Project Preferences>Working Units. You could however add a keyboard shortcut or toolbar button directly to that setting for ease of access.
If its the display of dimensions on the Dimension Tool, you can create a presets for Metric and Imperial and the quickly swap between them from the Quick Options palette along the bottom of the screen.
