Wishes
Trace Reference and the Worksheet Tool
gdford
It would be handy if the worksheet tool could capture the current trace reference.
Gary Ford
Self Employed - Modeling, Estimating, Construction
Archicad 12-26
AMD Ryzen 9 5900X 12-Core Processor
3701 Mhz, 12 Core(s), 24 Logical Processor(s)
(RAM) 128 GB
NVIDIA RTX A2000
1 REPLY 1
What do you mean by capture? Bring into the Worksheet Viewpoint as lines and fills and text?
If so, you can use the Switch Reference with Active button in the Trace Reference Palette, select the area you need with the Marquee, copy it to the Clipboard with CTRL+C, Switch Reference with Active again to go back to the Worksheet Viewpoint and paste those elements with CTRL+V.
Learn and get certified!
