I believe you can do this by selecting a door first and setting all your parameters and then as the door slab type select 'none'. I'm not sure if this is available using the ArchiCAD LIB but it is with some of the add-on LIB's
Gerald
Gerald
"The simplification of anything is always sensational" GKC
AC 25-4013 USA, CadImage Tools
2019 MacBook Pro 16" w/ AMD Radeon Pro 5600M GPU
OS X 11.6
2.4 Ghz 8 core i9, 64 GB RAM
27" LG 5K Monitor
