Wishes
Trim to Roof dialog: undo roof trim button
It's not a big issue just a 'cosmetic' fix to `Trim to Roof` dialog: undo roof trim button could be there (too) and not (only) in wall properties window.
3 REPLIES 3
You can trim to roof not only walls but also objects...so the global command would rather hurt the project not helping You...
Anyway - Trim to roof is IMHO a kind of "legacy" command - I do not use it since version 8.x...
Best Regards,
Piotr
Rob
jees, I have almost forgotten about Trim-to-Roof thingy.
I am using SEO for this exclusively.
Piotr, you're right, this feature is just a kind of leftover from the past.
::rk
Erika Epstein
What version of AC are you using?
An Undo trim to roof button appears on library parts etc when they have been so trimmed. You do need to check the tabs, sometimes its on the floor plan & section tab and on others its on the model tab.
Erika
Architect, Consultant
Mac OSX 10.11.1
AC5-18
Onuma System
Learn and get certified!
