2019-09-11 07:27 AM
2019-09-11 08:29 AM
2019-09-11 06:31 PM
2019-12-05 03:51 PM
Johan wrote:Totally agree and support this request. Perhaps it can be implemented in terms of existing AC concepts such as properties, but it would be nice to have a bit more automation around this. Doing things by hand when computers can do it for you is just silly.
We need to have types in Archicad :
Types are a way to easily and precisely handle a big number of identical occurences of a repetitive element.
If you define a window type for your project, with a defined size and a precise set of properties, you should be able to easy edit this type. It is not the case actually (yes you can select elements in 3D or in a schedule and modify them : it is not a satisfying answer to this wish, it is only a temporary and imperfect solution).
Favorites are not far away from this. A way of integrating types into Archicad would be to be able to "lock" parameters and properties in favorites. We could then be able to define types that are more or less flexible and efficiently propagate types modifications in a project.
No need for a new tool and it would give us flexibility. You can only "lock" what you want. So you could define a favorite for a window type with all it's properties entered but let the ability to change it's size.
It would be a game changer for our productivity.
2019-12-10 07:09 AM
2020-01-07 05:13 AM
2021-07-19 03:00 PM
2021-07-25 12:03 AM
