Wishes forum
Unique Slection dot to indicate Anchor Point of Object
Brad Elliott
When I select a Library object like a cabinet it would be very helpful if the anchor point was a different color or shape than the rest of the selection points. That way if I make a numeric change I can at least guess how it will act.
Even better give me an option in the pet palette to make the selection point I pick be the anchor point so I don't have to open the Library part to change it.
Mac OS12.6 AC26 USA Silicon
M1 Macbook Pro
2 REPLIES 2
__archiben
essential . . . for anything with an anchor. i have a feeling that if you search the forum there have already been wishes and discussions made along the same lines.
~/archiben
b e n f r o s t
Aussie John
not only that but there should indication which is the home storey. Maybe not on the plan but in the info palette.
Cheers John
[/size]
