2004-06-16 09:28 PM
2004-06-16 09:47 PM
2004-06-17 12:45 AM
2004-06-17 01:52 AM
Matthew wrote:Aha! How about this one: In 5.1, when you exploded a fill, you got lines. IIRC. Made it a lot easier to modify a symbol fill. Ironically, the workaround is to unlink an elevation of a wall which has the fill applied.
Yes James,
I can remember when fills viewed straight on were rendered as fills in elevation.
2004-06-18 01:14 AM
James wrote:That's funny. As I recall we had to put the fills into library parts and explode them. But my memory could be failing me in my old age. I don't remember ArchiCAD ever being able to explode fills directly (although PlotMaker has been able to do it forever).Matthew wrote:Aha! How about this one: In 5.1, when you exploded a fill, you got lines. IIRC. Made it a lot easier to modify a symbol fill. Ironically, the workaround is to unlink an elevation of a wall which has the fill applied.
Yes James,
2004-06-18 06:24 PM
If I recall correctly.
BTW: IIRC?
