Wishes forum
Update layer combinations from actual view!!!
We must be able to update a layer combination from the actual view!!!
It could be a button in the Quick layers toolbar: "update actual layer combination" (based on the actual visible layers)
The process now is a pain (identify the layers to be disabled, then open dialog, click on layer comb, find the layers, check or uncheck, then update the layer combination.) when it could just be a click.
I know you can just do a new layer comb, but then you have to apply it to every view where it is in and so on...
6 REPLIES 6
Erika Epstein
You can manage layer combos assigned to views in a schedule.
Erika
Architect, Consultant
Mac OSX 10.11.1
AC5-18
Onuma System
It sounds great Erika, but I don't find the method you're talking about.
Is there a schedule ready for that?
Erika Epstein
Under Project Indexes you can use the view list that comes with the program.
Create your own is another option.
Erika
Mac OSX 10.11.1
AC5-18
Onuma System
Erika wrote:
You can manage layer combos assigned to views in a schedule. You can buy phen375 diet pills here
that sounds very interesting. but, is there an automatic setting that can manage every views? thanks!
This is what Erika is talking about.
In the Project View, under Project Indexes, it is possible to create a View List which if effect is a Schedule. Many of the settings of Views can but shown in the Schedule as fields. The attached image shows the View List that exists as default in ARCHICAD 20.
Laszlo Nagy, Lead Moderator, Community Admin
Get Archicad Tips at https://twitter.com/laszlonagy
AMD Ryzen 1700X CPU, 48 GB RAM, NVidia GTX 1060 6GB, 500 GB NVMe SSD
2x28" (2560x1440), WIN10 PRO ENG, AC20-AC25
Loving Archicad since 1995
And here is the resulting View List (schedule) as shown in the attached image.
You can see that the individual fields of View can now be modified by clicking the appropriate cell and modifying its value. Some values are freely modifiable, in case of others you have to select the value from a drop-down list of available values.
