Wishes
Post your wishes about Graphisoft products: Archicad, BIMx, BIMcloud, and DDScad.
Update the GATE object!
vfrontiers
Please update the gate object to include:
1. Pair of Swinging gates (similar to D2)
2. Allow custom HANDLES
Duane
Visual Frontiers
AC25 :|: AC26 :|: AC27
:|: Enscape3.4:|:TwinMotion
9 REPLIES 9
+1 (now requires three characters - minimum). : - )
Think Like a Spec Writer
AC4.55 through 27 / USA AC27-4060 USA
Rhino 8 Mac
MacOS 14.2.1
Minh Nguyen
Graphisoft Alumni
Graphisoft Alumni
Thank you very much for sharing the wish!
May I ask which Gates object we are having here? In INT library, I couldn't find any Gate object from the Object tool, but we have the Garage doors in the Door tool. Is this correct what you mean here - Garage doors?
Best regards,
Minh
Minh Nguyen
Technical Support Engineer
GRAPHISOFT
Hi Minh, The garage door objects could do with a refresh as well. Large 6m x 4.5m rolling doors (metal and rubber), complete with hardware and structure please.
Rhino 8 Mac
MacOS 14.2.1
vfrontiers
mnguyen wrote:
Best regards,
Minh
I guess that answers that question.... D Hinged Gate 23 ... I see was not carried forward to ArchiCAD 24 😞
Duane
Visual Frontiers
it's in the USA AC24 Library:
Rhino 8 Mac
MacOS 14.2.1
vfrontiers
Aaron,
Yes I did end up finding it there... Not sure why my first search came up empty..
But still the issues mentioned persist..
D
Duane
Visual Frontiers
Minh Nguyen
Graphisoft Alumni
Graphisoft Alumni
Hi Duane and Aaron,
Thank you very much for your help! I registered the request as DEF-5030. Hopefully, our Product Management team will consider implementing it in the near future.
Aaron, if I understand you correctly, what you need is something similar to Roll-up Door 24, but with metal/rubber sheets or panels, and with fully customized hardware and structure, is that correct?
Best regards,
Minh
Minh Nguyen
GRAPHISOFT
Hey Minh, yes I think so. I’d be happy to send you some shop drawings to illustrate them more precisely. The are typically supported on a steel frame and the door rolls up into a drum. Clearance for the opening as well as all the hardware are usually critical.
Rhino 8 Mac
MacOS 14.2.1
Minh Nguyen
Graphisoft Alumni
Graphisoft Alumni
Hi Aaron,
That would be much better! The clearer we are with the wish, the higher the chance it gets to be implemented in the future!
Best regards,
Minh
Minh Nguyen
GRAPHISOFT
