Wishes
View PDF right after Publishing.
dcerezo
Cmon, this can't be hard. Just add a button next to the "Close" button that says, "View in Folder". Bam, that opens up my folder and I can double click on the PDF and see it.
The way it works now, given our detailed folder system here in the office, I have to "dig" for it.
This should be easy.
ArchiCAD 26 - iMac 27, Late 2019, 3.7 GHz Intel Core i5, 32GB Ram, Radeon Pro 8GB, macOS Sonoma
11 REPLIES 11
Thanks for confirming that you are using "Single File" from the publisher set.
Then correct, the current functionality doesn't help in this situation - I wasn't sure if it was a function that maybe wasn't discoverable also.
We can of course look at expanding this current solution, in this different situation and export based on your request (though it doesn't help with current versions of Archicad).
Are you always exporting to local file system? Or to BIMcloud?
Thanks.
James Badcock
Graphisoft Senior Product Manager
I always export to local file system. I don't use BIMcloud.
