2022-06-10 12:22 AM
Cmon, this can't be hard. Just add a button next to the "Close" button that says, "View in Folder". Bam, that opens up my folder and I can double click on the PDF and see it.
The way it works now, given our detailed folder system here in the office, I have to "dig" for it.
This should be easy.
2022-06-11 01:56 AM
Thanks for confirming that you are using "Single File" from the publisher set.
Then correct, the current functionality doesn't help in this situation - I wasn't sure if it was a function that maybe wasn't discoverable also.
We can of course look at expanding this current solution, in this different situation and export based on your request (though it doesn't help with current versions of Archicad).
Are you always exporting to local file system? Or to BIMcloud?
Thanks.
2022-06-12 08:01 PM
I always export to local file system. I don't use BIMcloud.
