sboydturner wrote:
JSN
Are the the files A B and C attached or overlaid in the central file? If they are only overlaid what you are experiencing is the correct result.
Regards
Scott
Scott,
Actually I tried both, but it did not make any difference in Archicad. So to sum it up again,
1st Problem: The links are (overlays and attachments) are not taken into consideration
2nd Problem: The RVT File is placed based on the Revit Project Base Point which will be set to the AC Origin.
It would be absolutely great if you could for example choose that the Shared Coordinates are used instead. Then the part models would find each other as well very quickly!
However, I am curious if you could elaborate your hint a bit more. Did it somehow work for you?
