2021-11-30 03:25 PM
Do you think it would be possible to have such an option, which would give you an information about the rule currently used on a specific element, while using particular Graphic Override.
For example, you see that your trees are red, and you would like to know why is that so. You click on that element, go into properties and there you have the information that there is that rule from the used graphic override which makes it red.
Or maybe there is such an option already?
Thanks!
2021-11-30 03:42 PM - edited 2021-11-30 03:42 PM
Ok!
I would like to delete this wish, because I have found out, that there is such an information.
When you select an object and hover your cursor over this element, there is a pop-up window which gives you info about its basic parameters, such as Name, Reservation, Layer etc.
If the object is affected by any rule from the Graphic Override, there is an information of which rule is it 🙂
2021-12-02 07:34 PM
at least you taught us something new
2021-12-03 02:34 AM
Yes we can delete (ignore) the wish now, but not remove the post as it is informative.
