Wishes
Post your wishes about Graphisoft products: Archicad, BIMx, BIMcloud, and DDScad.
WORKING UNIT
I am a freelance architect, i work for clients from several continents. It is so frustrating to work in ArchiCAD using different units.
I usually work in mm (metric), so if for instance my client tells me the head room is 8ft, i cannot directly inert that in the storey setting while using my metric "working units". I have two options, either i go to the options and change working units, or i look for a calculator to make the conversion for the units.
Unlike in other software, i could just insert the 8 followed by "ft" to specify i am referring to a unit other than my current working unit.
It will make my work in archicad so much faster!
Ghaleb Khadra
Graphisoft Alumni
Graphisoft Alumni
Hi All,
I'm glad to say we took notice of this request and have added an official Wish into our database.
For future reference, you can refer to this as Wish 12590
Thank you all for your contribution and participation on the forums.
I wish you all a great day!
Kind regards,
Ghaleb
Ghaleb Khadra
BIM Expert
GRAPHISOFT
https://helpcenter.graphisoft.com
RandyC
i agree In Canada we work with both imperial and metric and switching back and forth is clumsy -
Municipalities want metric , Builders want imperial.
ArchiCAD 4.5 --- 27 , Win 10 , dual monitors, 64 gb ram,Nvidia GeforceRTX 2080 TI, I-9
Ghaleb Khadra
Graphisoft Alumni
Graphisoft Alumni
Hi All,
Kind regards,
Ghaleb
Ghaleb Khadra
BIM Expert
GRAPHISOFT
