Wishes
Post your wishes about Graphisoft products: Archicad, BIMx, BIMcloud, and DDScad.
Walking Line in Stair Tool in AC21
Dave Jochum
The walking line symbol does not orient properly with regard to the up/down text. The walking line should point up from the lower floor and down from the upper floor. Walking line always points in either the up or down direction, depending on setting, regardless of floor being viewed. Story sensitivity is lacking.
Dave Jochum
J o c h u m A R C H I T E C T S http://www.jochumarchitects.com
MBP 16" (M1 Max) 64 GB•OS 13.5.2•AC 27 Silicon (latest build)
31 REPLIES 31
Laura Yanoviak
I noticed this too. Looks like I'll have to continue to use my separate Walking Line Object until this is fixed.
AC26 US (5002) on Mac OS Ventura 13.5
the north american elephant has entered the room. problem.
Think Like a Spec Writer
AC4.55 through 27 / USA AC27-4060 USA
Rhino 8 Mac
MacOS 14.2.1
Having moved from Revit to Archicad, I'm surprised that this hasn't already been implemented.
Surely it's relatively simple to do.
Laura Yanoviak
It's been implemented before, it's just missing from the new tool. Hopefully it will be corrected in the first hotfix.
So it's in AC20?
Eduardo Rolon
AC 20 has a different and now obsolete Stair tool so going back does not necessarily helps.
Eduardo Rolón AIA NCARB
AC27 US/INT -> AC08
another Moderator
ksjhawk
I just don't get it. Why is this a wish list item? Knowing the effort that went into the new stair tool, I have been racking my brain trying to figure out how to make the arrow reverse direction. Guess I should head here sooner in the future.
MacBook Pro Apple M1 Max 64GB ram
OS X 12.4
AC26 - AC6.5
Laura Yanoviak
I'd like to think it's a bug and hope it will be fixed soon.
It is a bit crazy that you can change the direction of the walking line (Walking Line 21 object) in the visible and hidden parts of the stair (so it can point in 2 different direction on the one storey) but you can't alter the direction per storey.
I am sure (or at least I hope) it could be solved with a little? GDL scripting.
