Wishes
Post your wishes about Graphisoft products: Archicad, BIMx, BIMcloud, and DDScad.
Walking Line in Stair Tool in AC21
Dave Jochum
The walking line symbol does not orient properly with regard to the up/down text. The walking line should point up from the lower floor and down from the upper floor. Walking line always points in either the up or down direction, depending on setting, regardless of floor being viewed. Story sensitivity is lacking.
Dave Jochum
J o c h u m A R C H I T E C T S http://www.jochumarchitects.com
MBP 16" (M1 Max) 64 GB•OS 13.5.2•AC 27 Silicon (latest build)
31 REPLIES 31
Tom Krowka
that does help. It's going to take a while to get used to the controls. But thanks, Tom
Tom Krowka Architect
Windows 11, AC Version 26
Thomas@wkarchwk.com
www.walshkrowka.com
As far as I can tell, update 4022 has not resolved the stair problem. This is a very frustrating flaw in an otherwise functional tool.
Does anyone have a sense if the walk line issues are on Graphisoft's radar?
I tried to explain the "down arrows only" approach to a contractor in California and he found it extremely confusing.
This just seems like such an easy fix!
Eduardo Rolon
Still using my workaround pre AC21 and manually drawing the walk line.
Eduardo Rolón AIA NCARB
AC27 US/INT -> AC08
another Moderator
Tom Krowka
Me too.
Thomas@wkarchwk.com
www.walshkrowka.com
I vote Essential to Infinity. Squared
Think Like a Spec Writer
AC4.55 through 27 / USA AC27-4060 USA
Rhino 8 Mac
MacOS 14.2.1
Tom Krowka
Looks like the essentials have it.
Thomas@wkarchwk.com
www.walshkrowka.com
Dukatas
Looks like we have it fixed with Build 5555.
Ben Hruska
ArchiCAD 3.1 - 24
iMac
Yes but you must use "Walking Line 21" - not the built-in line.
I recently heard on a ArchiCAD webinar that the stair arrow direction, and up / down text had be "fixed" for the North American market. Is this the case? If so, what build?
Thomas Allan Palmer
Architect AIBC MRAIC
ArchiCAD 24 MacBook Pro
Mac OS Catalina 10.15.6
Dukatas
It is mostly fixed. Doesn't work well when you have the walk line non-continuous at landings. GRRR
Ben Hruska
ArchiCAD 3.1 - 24
iMac
