2020-04-15 03:38 PM
2020-04-15 05:13 PM
2020-04-16 10:50 AM
2020-04-16 01:56 PM
2020-04-16 02:51 PM
2020-04-17 04:26 PM
DGSketcher wrote:I completely agree that solution could work. Many times working with windows I think it´s my own incompetence what prevents me from doing simple things, mostly related to the opening, but threads like this makes me think there are important and somewhat baffling omissions in the current tools
Fair comment. GS have it in their power to put both solutions together such that we have an opening type object and the head detail could be integrated from a complex profile. This kind of solution works with Curtain Walls where we can select a profile to work with mullions & transoms, so why not modify the head / arch detail to work with a CP? If they wanted they could even do the same for sills & jamb closures (bottom & sides).
2020-04-21 12:11 AM
Minh Nguyen
Technical Support Engineer
GRAPHISOFT
2020-05-03 12:12 PM
DGSketcher wrote:Hello everyone! I was thinking about the possibility of using the platband, developing the possibility of choosing its structure, as well as having the possibility of quantifying it!
I agree there should have been a basic closure developed by now, BUT I also think 3D modelling & BIM is gaining momentum and we are at a point where adding a complex profile & segmented beam containing structure & finishes over an opening is becoming a more appropriate solution.
Now if we could just have profiles with a "Level of Detail" option...
