2007-12-13 08:17 PM
2007-12-14 01:04 AM
Paul wrote:(Edited) Well, this could work better, but I wouldn't call it impossible.
We need a way to fillet & chamfer walls at corners such that outer radius of fillet can be less than width of wall
For "organic" looking construction (stone, adobe etc), where corners are not razor sharp, a small fillet to corners is desirable, but currently impossible unless user switches to polygonal walls
2007-12-14 03:34 AM
Thomas wrote:Hi - Thanks Thomas, and quite right, it is not truly "impossible" - though as you guessed I meant impossible without messy workarounds such as this (I guess not many things are truly impossible in ArchiCAD, given the time & the will)
...Well, this could work better, but I wouldn't call it impossible.
2007-12-14 05:38 AM
Subject | Likes |
15 | |
14 | |
11 | |
11 | |
10 |
