Wishes
We need to be able to open all kind of attributes settings without closing actual window
Please!
For example:
Open material editor directly from composite settings
Open surface editor directly from material settings
Open fill editor directly from surface editor
Tired to close material editor window, open fills window, finding right fill, editing, close window, find right material, open window, wrong fill it was....
Maybe this should be moved to User Interface Wishes, but I canät any longer change that
While I would love to have the ability to drill down into the attributes as you described, there may be some users who shouldn't be able to drill down that easily. Maybe there could be an option in the Work Environment settings to allow the option on/off.
Guru
If you are using Teamwork, then you could just restrict their edit permissions?
Win10 | R5 2600 | 16GB | GTX1660
