2004-05-21 03:57 PM
2004-05-28 12:43 AM
2004-05-28 06:45 AM
Weston wrote:Speaking of Preference Items
12) A setting underpreferences/drawing attributes that sets the default preview method that PM4 places an imported drawing with.
2004-05-28 06:53 AM
2004-05-28 10:05 AM
TomWaltz wrote:Nice point Tom. If Plotmaker is going to remain an external program, I belive this wish should be made a reality very soon.
7) Teamwork-like sharing
2004-05-28 12:06 PM
tsturm wrote:Goto Drawing usage, select all the relevant placed drawings, open Settings, click on Keep original position in the Title section
13) Setting to get Title Label to show as Black Lines and Auto update to resized drawing. I get tired of going to the drawing settings for each drawing on my page just to get the Title to snap to the corner versus floating around on the page.
tsturm wrote:You on Mac? It is there in the Toolbar.
14) A Publish button on the window versus getting it from the Menu Bar.
tsturm wrote:Set the Set Publishing properties to Plot, specify Plot settings.
15) Being able to setup a Publish set for Plotting. There currently seems to be the settings to get it done, but how is it done?
tsturm wrote:Set the Publishing properties to Print, choose PDF printer. Or just Print to a PDF device, much easier.
16) Being able to Publish to PDF.
tsturm wrote:Specify the fill display options in ArchiCAD while defining the view, and then in PlotMaker Display options choose Keep original settings.
17) Being able to set the display settings of pages separately. Vectoral versus Bitmap. Some of our drawings look there best when printed using Bitmap. They also queue up faster. Then there are some that must be printed using Vector due to the fills of brick or paving. This could also be done on a drawing to drawing basis.
2004-05-28 04:58 PM
Djordje wrote:tsturm wrote:Goto Drawing usage, select all the relevant placed drawings, open Settings, click on Keep original position in the Title section
Djordje wrote:Why yes I am. I take it by that response, you being on the PC have this button in your tool bar !!! Not sure why you got it and I didn't. Was there a slip in development of the Mac or the PC version??tsturm wrote:You on Mac? It is there in the Toolbar.
2004-05-28 08:52 PM
tsturm wrote:Yes, it should be on by default. First thing I do ...
I did not say that it could not be done. It is just annoying to have to open the settings box to make the change. Why couldn't there be a preference for this option was the point I was trying to make.
2004-06-02 07:28 AM
2004-06-04 12:08 AM
2004-07-01 12:12 AM
