Would like to see windows working similar to the curtain wall, where you can define any number and configuration of sashes and make each sash operable as you see fit.
Or at the very least - more available in the libraries. Right now there is a Fixed Lower with an Upper Awning, but no Fixed Upper with a Lower Awning. There is no way to make an asymmetrical XOX sliding window, which I see as being pretty common in today's construction.
AC 6-27 - Intel i9-9900K - RTX3090 - Windows 11 - 64GB RAM
