Wishes forum
Window and Door Materials and Colors
4hotshoes
As it is now, Walls, Slabs, Roofs, Beams, Columns, Stairs and Railings all use "Building Material" to regulate surface appearance in the 3D model, which makes it easy to create color schemes for clients to approve. But Windows and Doors need an update as they use Surfaces to regulate appearances in the 3D model. When using the "Building Material" for color/texture, it becomes a "one-stop" location to create and change schemes.
For example, If I could create a building materials for Window Sash (indoor/Outdoor), Window frame (indoor/Outdoor), Window Casing (indoor/Outdoor) and change all globally for the project from the Building Materials toolbox. Then I could also coordinate the same materials for doors at the same time if doors are provided by the window manufacturer (common in residential).
As is is now, I have to create custom selections to separate exterior doors from interior doors, while the main entry is likely unique. Then I may have interior windows (rare) that are not at all like he exterior. This process of change is tedious and could be immensely simplified if the Doors and Windows Tools were updated to follow the direction of other Tools that use Building Materials rather than Surfaces.
Todd Oeftger
Ligature Studio
AC23 and AC24 Mac MacBook Pro 15", 2019, 2.3 GHz i9, 32GB, Radeon Pro 560X 4GB, 500GB SSD, 32" Samsung Display (2560x1440)
5 REPLIES 5
DGSketcher
Good suggestion. This is the kind of thing GS should be doing to simplify the design process and trim the epic number of settings required in elements. As you say it coordinates components across the project, which is a big plus.
Apple iMac macOS Big Sur / AC24UKI (most recent builds)
Indeed a good suggestion.
GS should focus on optimizing the general user interface. Too much clicks for simple tasks.
4hotshoes
I would be interested in hearing from the person who voted no. How do you work this out in the current surface assignment that is better than proposed?
Todd Oeftger
Ligature Studio
Minh Nguyen
Graphisoft Moderator
Hi All,
Thank you very much for creating this poll, and for those of you who voted to express their opinion.
I am happy to say we took notice of this wish and I have added it into our WishList database (please refer to it in the future as Wish GISS-603). Hopefully, our Product Management team will adopt this one in the future.
Thank you all once more, and I wish you a great day!
Best regards,
Minh
Minh Nguyen
Technical Support Engineer
GRAPHISOFT
Lingwisyer
So the current surface options would just become overrides much like they are for other components.
AC18-23 AUS 7000
Self-taught, bend it till it breaks.
Win10 | E5620 x 2 | 24GB | K2200
