2019-10-22 09:33 PM
2020-02-04 11:26 AM
2020-05-22 09:09 PM
2020-05-24 10:48 PM
Door and Window Standard Fixtures and Fittings
The following standard ARCHICAD library door or window parametric elements and
functionality will be added to each door or window automatically:
Windows
– Wall Opening – Reveal
– Wall Opening – Wall Closure
– Wall Opening – Wall Inset
– Wall Opening – Masonry Arch
– Wall Opening – Attributes
– Fixtures & Fittings – Sill
– Fixtures & Fittings – Board
– Fixtures & Fittings – Casing Inside/outside
– Fixtures & Fittings – Sunshade
– Fixtures & Fittings – Custom Corner
– Fixtures & Fittings – Attributes
Door
– Fixtures & Fittings – Threshold
System predefined parameters for Doors and Windows
– Width – width of Door/Window set
– Height – height of Door/Window set
– Nominal Frame Thickness – frame thickness of Door/Window set
– Orientation Displaying – If set to ‘Automatic’, Label Default Position and Label Reversed
Position values will be used for Door/Window labels and in Interactive Schedules. If set
to ‘Custom’, the value of Custom Orientation parameter will be used instead.
– Custom Orientation – used in conjunction with Orientation Displaying parameter
– Label Default Position – (set to ‘L’ for ‘Left’ by default) used in conjunction with
– Label Reversed Position – (set to ‘R’ for ‘Right’ by default) used in conjunction with
– IFC Operation – IFC operation definition
– Surfaces > Door/Window Tolerance Outer Surface – outer surface of tolerance infill
– Surfaces > Door/Window Tolerance Inner Surface – inner surface of tolerance infill
– Surfaces > Door/Window Handle Surface – surface of Door/Window handle(s)
– Pens > Opening Line Pen – pen of Door/Window opening lines
2020-05-25 04:16 AM
2020-05-25 08:24 PM
2020-05-28 06:24 PM
I have not seen anyone here mention Graphisoft's free "Library Part Maker" here. Available for 23 and back to 21 or so I think. This is a free (had to say it twice) tool to ArchiPLUS subscribers, and I believe is available worldwide, but it seems to have gotten very little discussion here on the forums overall in spite of its power.
2020-05-28 06:51 PM
Brad wrote:I used it in beta and was really impressed then. So much more powerful than simply 'save as' library part.
Karl,
Have you used this? Has anyone? Does it work? Is there any information on how to actually use it?
2020-05-28 08:39 PM
2020-05-28 09:18 PM
2020-05-28 10:23 PM
