Wishes forum
Window/door schedule - material adjustment when not in use
P_Arcke
What I'd really like to see adjusted is the ability to edit fields if they aren't currently active (ie: change the material of a sill even if it's inactive. Typically there's one chosen by default and I want to change it more easily when not in use to be a blank material listed as "---".
My current work around is to change the door/window type to one that has a sill, then change the sill material, then change it back to the original window type. It's locked otherwise.
0 REPLIES 0
Labels
