Have you tried settings up favourites for your office template? You can define the pens, layers, line-types (for overhead display etc) for commonly used model elements and tell staff to use those as a starting point if they want to deviate from a standard solution.
Another thing I've seen done is making a sort of 'live' legend of walls, roofs etc in a hotlinked module on a story below the actual model at a large enough distance to not interact with the model. This might screw with quantity take off though, but the idea is to pick up the proper settings with syringe.
www.leloup.nlArchiCAD 9-26NED FULL
Windows 10 Pro
Adobe Design Premium CS5
