Wishes forum
Wish: Split angle dimension and add multiple points at once.
I've been setting out some folding doors which have changed several times now and each time I need to dimension the angle for setting out - See screenshot. this would be MUCH quicker if the angle dimension had the same functionality as the linear dimension tool.
problems:
You can't split the angled dimension
you can't add more than one angle point at a time - so when dimensioning multiple angles as per the screenshot, one needs to click each line, set the angle marker position, then do the next one and then align them all - many steps!
No screenshot, but I get what you mean. Annoying and tedious stuff!
www.leloup.nl
ArchiCAD 9-24 NED FULL
Windows 10 Pro
Adobe Design Premium CS5
attached now..?
Labels
