I've been setting out some folding doors which have changed several times now and each time I need to dimension the angle for setting out - See screenshot. this would be MUCH quicker if the angle dimension had the same functionality as the linear dimension tool.
problems:
You can't split the angled dimension
you can't add more than one angle point at a time - so when dimensioning multiple angles as per the screenshot, one needs to click each line, set the angle marker position, then do the next one and then align them all - many steps!
